AutoCAD 2000/2000i/2002 Archive (Read Only)
importing PDF files
5 REPLIES 5
201 Views, 5 Replies
importing PDF files
i am having trouble importing PDF files. all i get is an image that says
Acrobat Document. any ideas?
thanks
using 2002
cd
5 REPLIES 5
You cant import PDF's into ACAD,
If its text you can copy & paste or if its an image open it in Photoshop and
save as a bitmap image
Bruce
"plothead" wrote in message
news:185406259B68364704F7FA0F5DB43FE5@in.WebX.maYIadrTaRb...
> thanks
> using 2002
> cd
If you have Adobe Illustator, you can then open the pdf file into that
program. After opening the file, you can then export the file as an AutoCAD
drawing. The only problem is another software program to purchase, unless
you can find someone who has a copy who can do the job for you.Good luck.
Semyon Solomon
thanks
using 2002
cd
there is freeware out there, Ghostscript/Ghostview specifically, that
will be convert a PDF to a DXF.
D
David,
GSView on Windows systems 🙂
BTW it's PStoEdit that takes care of the actual conversion, together with
GhostScript. GSView is the GUI that makes it a bit friendlier.
Govert
David Renaud schreef in berichtnieuws
3CC00455.5352A1F7@reiengineering.com...
> D
On Fri, 19 Apr 2002 04:49:41 -0700, David Renaud
You also need a little package called PSTOEDIT as well 😉
Ian A. White, CPEng
WAI Engineering
Sydney 2000
Australia
Ph: +61 418 203 229
Fax: +61 2 9622 0450
Home Page: www.wai.com.au
