AutoCAD 2000/2000i/2002 Archive (Read Only)
Image Types for Attachment
4 REPLIES 4
147 Views, 4 Replies
Just getting into using Acad 2002 from V14 and I had to make a tiff image uncompressed to attach it, the LZW compressed version (which I generally use) was flagged up as invalid. Have they limited the options for images that can be attached? It is no major hardship, apart form storage space.
4 REPLIES 4
Error inserting TIFF files: Invalid File Format
http://support.autodesk.com/getdoc.asp?id=TS67210
Please, DO NOT send technical requests to me via private e-mail
Tracy Lincoln, Assistant Moderator
Autodesk Discussion Groups Forum Moderator Program
Discussion Group Links:
Index: http://discussion.autodesk.com
Rules: http://discussion.autodesk.com/webx?groundrules
Product Support: http://support.autodesk.com/
Thanks for the confirmation.
Why has LZW compression support been removed?
Don't know, but i believe the LZW compression method is no freeware.
Your belief is correct.
Tracy W. Lincoln, Assistant Moderator
