AutoCAD 2000/2000i/2002 Archive (Read Only)
Hyperlink limitations
3 REPLIES 3
508 Views, 3 Replies
I am "Pasting as Hyperlink" to a block in my
drawing and my path to the file has a pound symbol (#) in the path.  I have
found out that the "#" symbol is the source of my problem when I try to activate
or "open" the hyperlink.  It actuallly doesn't work, and I get an error
dialog box stating, "The system cannot find the path specified".  Are there
any other symbols that I should consider a problem with respect to paths to
files?  Also, is there any escape character that I could place in front of
these symbols to make the hyperlink read the character literally, just like we
do for lisp?
3 REPLIES 3
I think the problem in your case is that the "#" is
a "bookmark" in html
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
have found out that the "#" symbol is the source of my problem when I try to
activate or "open" the hyperlink.  It actuallly doesn't work, and I get
an error dialog box stating, "The system cannot find the path
specified".  Are there any other symbols that I should consider a
problem with respect to paths to files?  Also, is there any escape
character that I could place in front of these symbols to make the hyperlink
read the character literally, just like we do for
lisp?
Hi
I’m having problems with hyperlinking on a drawing to hyperlink to a drawing in my Standard folder. The error message comes up with (THE SYSTEM CANNOT FIND THE PATH SPECIFIED) when I try open from the hyperlink I set up
I have just upgraded to AutoCAD 2012 from AutoCAD 2004, where I set up the hyperlink up fine with no problems on the older version, I have also had Windows 7 installed but doubt that that has any effect.
Please could you give me the info to this problem and or direct me in the correct path?
pendean
Can you provide specifics? like at least a path .... .
