AutoCAD 2000/2000i/2002 Archive (Read Only)
How turn off active assistant!!!
4 REPLIES 4
2024 Views, 4 Replies
How in the world do you turn off the active assistant
in Acad 2002?!
4 REPLIES 4
davidm_adn
You should have a little icon in the task bar (bottom right of the screen). Right click it, and you can exit it from there. Better still, in settings, you can untick 'show on start' and you'll never see it again. Unless you turn it back on using the help menu....
> in Acad 2002?!
Quoting the Active Assistance's "Using Active Assistance"
To turn off Active Assistance
right-click on the Assist icon located in your System tray and choose
Exit. The System tray is located in the lower-right corner of the
Windows task bar.
Please, DO NOT send technical requests to me via private e-mail
Tracy Lincoln
Assistant Moderator, Autodesk Discussion Groups
Discussion Group Links:
Index: http://discussion.autodesk.com
Rules: http://discussion.autodesk.com/webx?groundrules
Product Support: http://support.autodesk.com/
Knowledge Base: http://support.autodesk.com/ViewAnswerworks.asp
Downloads: http://support.autodesk.com/Downloads.asp
>Windows task bar.
OK Tracy..... thanks!
Dumb question here..... but how do you turn the active
assistant "on"?
> assistant "on"?
At the command prompt:
ASSIST
Tracy Lincoln
