I don't know, there is a place to set an offset for the origin that you could
check. You know about the BASE command? I never used it in paperspace but in
mspace, BASE moves the 0,0 for xreffing/inserting (probably not). Perhaps you
could post a sample in customer files, it's hard to imagine. Could they have set
the paperspace scale some funny way?
Dana Muse wrote:
> My problem is that when I move the title block to 0,0, it is NOT at the
> lower left corner of the margin. For some reason on some of the older
> drawings the corner of the printable area margin is not 0,0. Sometimes, the
> 0,0 point is way off the page in the gray area of the layout. Only by
> creating a new paper space layout can I reset the origin to the corner of
> the paper margin.
> "Paul Furman"
wrote in message
> news:3B807476.89A51FC5@edgehill.net...
> Good question. The corner of the printable area margin is 0,0. The margin
> depends on the printer/plotter. That's just the way it is. Move your title
> block
> & everything to the 0,0,0 origin.
> Dana Muse wrote:
> > Sometimes when opening old drawings, the origin in the paper space layout
> is
> > not at the bottom left corner of the paper margin. Is there anyway to
> > re-set the 0,0,0 origin point to the bottom left corner of the margin?
> Can
> > I "snap" onto the dashed margin-box somehow, or must I creat a new layout
> > and copy my old title block into it? This can be very tedious when
> working
> > with lots of old drawings.
> > Thanks,
> > Dana M.
