AutoCAD 2000/2000i/2002 Archive (Read Only)
Exit drawing = Exit Autocad
8 REPLIES 8
Message 1 of 9
498 Views, 8 Replies
Hello fellow users,
I'm sorry if this has been asked before, but it's really trying my
patience..........
I have say 4 drawings open in 1 instance of Acad 2002.
I open another drawing up, not the 1 I want. Close this drawing, and
Acad closes down without any prompts to save the 4 previous drawings.
Any unsaved data is lost.
Anyone experienced this?
TIA.
Jon Kay
Boundary Metal Ltd
8 REPLIES 8
Message 2 of 9
Since it doesn't happen to most of us, how about more details about your
system and how you access files and details in between.
Dean Saadallah
Add-on products for LT
http://www.pendean.com/lt
Message 3 of 9
Dean,
Win 2K Pro SP4
HP P4
1 Gig Ram
Nvidia Quadro4 750 XGL
-Acad LT2002
-Inventor6 SP2
-MDT6
21" & 19" dual monitors
Start Acad2002, open drawing, work.
Minimise drawing, open another drawing, work
Close 2nd drawing (do you wish to save changes? Yes/No)
Both drawings close (without prompts to save dwg 1), and Acad exits.
Changes made to dwg 1 after last autosave are lost.
Thanks for your time,
Jon Kay
Boundary Metal Ltd
Message 4 of 9
On Fri, 29 Aug 2003 06:14:35 -0700, "Jon Kay"
wrote:
>Dean,
>Win 2K Pro SP4
>HP P4
>1 Gig Ram
>-Acad LT2002
>-Inventor6 SP2
>-MDT6
How are you closing the 2nd drawing?
Ian A. White, CPEng
ianwhite@wai.com.au
WAI Engineering
Sydney 2000
Australia
Ph: +61 418 203 229
Fax: +61 2 9622 0450
Home Page: www.wai.com.au
Message 5 of 9
snip
Clicking on the top right hand side "X" close button.
Acad exits whether I choose to save drawing 2 or not
Best wishes,
Jon Kay
Boundary Metal Ltd
Message 6 of 9
On Tue, 2 Sep 2003 03:45:03 -0700, "Jon Kay"
wrote:
>snip
Check the setting of the EXPERT variable on your system. It sounds like
something has set it to not warn you. The help system will tell you
what the default value should be.
Ian A. White, CPEng
ianwhite@wai.com.au
WAI Engineering
Sydney 2000
Australia
Ph: +61 418 203 229
Message 7 of 9
Thanks for your suggestion Ian,
Expert variable is set to the default of 0 (show all prompts)
Even if this was the case, closing one drawing should not
exit the program.
Strange enough, it doesn't happen all the time.
I guess I will have to make sure all drawings have been saved before
closing one drawing.
Jon Kay
Boundary Metal Ltd
Message 8 of 9
It sounds as if your AutoCAD is crashing without an error message. I've
seen this before, there's just a problem with the drawing(s).
Try to fix the bad drawing(s)...the one(s) that cause(s) AutoCAD to abruptly
quit when you close. Remove any unnecessary objects, purge all extraneous
items, etc. If this doesn't work, copy/paste the objects you need (don't
select "all") into a brand new drawing.
Good luck.
Steve Tatro
CADMAN
THP Limited, Inc.
Cincinnati, Ohio
"Jon Kay" wrote in message
news:7224AEA11E8FE653CA5A753C593EF836@in.WebX.maYIadrTaRb...
> exit the program.
> Jon Kay
> Boundary Metal Ltd
Message 9 of 9
Thanks for the reply Steve,
I think I will just copy / paste what I need into a new drawing and be done
with it.
I'm off down the pub now (18-00 hours).
Best wishes,
Jon Kay
Boundary Metal Ltd
