AutoCAD 2000/2000i/2002 Archive
1 Kudo
Post 1 of 4
dynamic link library Msvcp70.dll
202 Views, 3 Replies
11-09-2003 10:35 PM
When starting AutoCAD 2002 (Note: AutoCAD 2004 is already installed and de-installed and re-installed on this machine) the follwing message appears:
"The dynamic link library msvcp70.dlll could not be found in the specified pat ......."
Clicking once or twice the message disappears, and I seem not having any problems with AutoCAD.
Is there anyon (Autodesk) who knows this problem and to solve it?
Thanks.
Edward Winter
*McSwain, R.K.
Post 2 of 4
Re: dynamic link library Msvcp70.dll
11-09-2003 11:32 PM in reply to: ewinter
If you want a response from Autodesk, call your dealer, as they are your primary support outlet. This is a user forum.
1 Kudo
Post 3 of 4
Re:
11-10-2003 03:57 PM in reply to: ewinter
R.K. McSwain wrote:
"If you want a response from Autodesk, call your dealer, as they are your primary support outlet. This is a user forum."
Okay, put (Autodesk) a side, if this botters you, and I leave the question with "Does anyone know..."
Regards.
New Member
0 Kudos
Post 4 of 4
Re:
12-19-2003 01:59 PM in reply to: ewinter
There are actually two .dll files that AutoCAD 2002 is missing after AutoCAD 2004 is installed.
MSVCR70.dll and MSVCP70.dll
I found the files in my "C:\Program Files\AutoCAD 2004" folder and copied them to my "C:\Program Files\AutoCAD 2002" folder. Problem solved.
