AutoCAD 2000/2000i/2002 Archive (Read Only)
Delete Layer Filters
6 REPLIES 6
222 Views, 6 Replies
Anybody got a quick way to delete all the Named Layer Filters in a dwg?
TIA
6 REPLIES 6
See the CDGPurge from http://www.caddevelopmentgroup.com/
Please, DO NOT send technical requests to me via private e-mail
Tracy Lincoln
Assistant Moderator, Autodesk Discussion Groups
Discussion Group Links:
Index: http://discussion.autodesk.com
Rules: http://discussion.autodesk.com/webx?groundrules
Product Support: http://support.autodesk.com/
Knowledge Base: http://support.autodesk.com/ViewAnswerworks.asp
Downloads: http://support.autodesk.com/Downloads.asp
Thank you very much, Tracy. It's just what the doctor ordered. Thanks for
getting back to me so quickly. I've already shared this slick little tool
around the office.
Don R
"Tracy W. Lincoln" wrote in message
news:3E1C8838.FE6E76EA@iroquois.com...
> Tracy Lincoln
You're welcome, but the thanks should be directed to CDG.
Tracy Lincoln
Just a note. I ran across and loaded the CDG Purge freebie recently myself.
It's seems to be a powerful little utility for clearing out the junk and I
have added it to my arsenal. A warning though, I have had some files become
corrupted after using it. Maybe I just need to learn more about how to use
it.
-Edgetrimmer
news:3E1C9AC7.C267CEDF@iroquois.com...
> Tracy Lincoln
Followup to my own post... Probably the option to be cautious about when
using CDG Purge is purging registered applications.
-Edgetrimmer
I had hoped that it would rid Architect's shared dwgs of the ADT registered
application, but no such luck. I would add to the caution relayed by
Edgetrimmer, watch out that you don't use Purge All indiscriminately. Used
responsibly, this is a great tool. Thanks CDG!
"Edgetrimmer" wrote in message
news:DAD819F8747CA81A1F2CE6DDD9D43B69@in.WebX.maYIadrTaRb...
> -Edgetrimmer
