Dean,
I'm sure you knew this, but for the others in here.
R (vs. ROT) will work prior to insertion (paste, pastespec) as will:
R (rotation angle)
S (scales X,Y,Z)
X (scales X only)
Y (scales Y only)
Z (scales Z only)
PR (Preview Rotate)
PS (Preview X,Y,Z Scale)
PX (Preview X scale)
PY (Preview Y scale)
PZ (Preview Z scale)
I never understood why someone would want to type in more letters to get less
(as all the Preview options simply Previews the inserting object(s) but
reverts back and makes you retype in any non-default values)?
DO NOT send technical requests to me via private e-mail
Tracy Lincoln
Assistant Moderator, Autodesk Discussion Groups
Discussion Group Links:
Index: http://discussion.autodesk.com
Rules: http://discussion.autodesk.com/webx?groundrules
Product Support: http://support.autodesk.com/
Knowledge Base: http://support.autodesk.com/ViewAnswerworks.asp
Downloads: http://support.autodesk.com/Downloads.asp
Dean Saadallah wrote:
> Type ROT at the command prompt before you click on a location in your
> drawing to drop it at... .
> Dean Saadallah
> http://www.pendean.com
> Expanded Links Page
> http://www.pendean.com/lt/links.htm
> "adam1"
wrote in message
> news:f0e1eec.-1@WebX.maYIadrTaRb...
> > is there any way to paste an object and have controll of the rotation? i
> dont want to make it a block.
