AutoCAD 2000/2000i/2002 Archive (Read Only)
Convert True Type Fonts to vector outlines
3 REPLIES 3
8215 Views, 3 Replies
I want to be able to convert fonts to vectors. Graphic packages call this Fonts to Curves.
The end result is back in AutoCAD.
Can it be done with True Type and or Postscript fonts?
Any Help is appreciated.
Dave
3 REPLIES 3
Dave
If the text can be brought into AutoCAD, use the Express Tool to explode
text, or do a WMFOUT of the text, followed by a WMFIN of the file
created. Re-scale it if necessary and then explode it. You will have a
series of lines which you can join into polylines.
Ian A. White, CPEng
WAI Engineering
Sydney 2000
Australia
Ph: +61 418 203 229
Fax: +61 2 9622 0450
Home Page: www.wai.com.au
Select EXPRESS on Menu bar, then TEXT-EXPLODE TEXT, select the text you want to explode.
That's it.
Ky Nguyen
Ky and Ian,
This is a great start to my needs.
THANK YOU!
Dave
