AutoCAD 2000/2000i/2002 Archive
*Veilleux, Mike
Post 1 of 33
convert PDF to DWG or DXF
548 Views, 32 Replies
11-01-2001 10:46 PM
Is it possible to convert a PDF to DWG or DXF? I need to revise a drawing
that I only have in PDF form right now. The only other option would be to
create the drawing from scratch, which would be very labor intensive...
Mike Veilleux
CAD Manager
LBG, Inc.
Veilleux@lbghq.com
www.lbgweb.com
*Renaud, David
Post 2 of 33
Re: convert PDF to DWG or DXF
11-01-2001 10:46 PM in reply to: *Veilleux, Mike
Mike,
Get Gostview/Ghostscript off the web (freeware). It can convert a pdf to
a dxf.
David
*Veilleux, Mike
Post 3 of 33
Re:
11-01-2001 11:07 PM in reply to: *Veilleux, Mike
I downloaded Ghostscript 7.0, but I have no idea how to use to it to convert
a PDF to DXF. It seems like a programmer's tool, which I am not.....
any other software?
"David Renaud" wrote in message
news:3BE2A274.808FF864@reiengineering.com...
> Mike,
> a dxf.
> David
*Renaud, David
Post 4 of 33
Re:
Mike,
You need to have both Ghostscript AND Ghostview. Ghostview is the
user-friendly interface with Ghostscript. Use Ghostview when you start.
Confusing way to do it (2 seperate software packages), but it works.
David
*jmorris
Post 5 of 33
Re:
>David
David.... have you been pretty satisfied with the above
combo over the Acrobat package?
Does the combo give you pretty much the same
functionality as full Acrobat?
*Renaud, David
Post 6 of 33
Re:
11-01-2001 11:17 PM in reply to: *Veilleux, Mike
Hey John,
I've never used anything but the Reader, so I really can't say. I would
have to think, though, that the Adobe stuff is better. The main thing
Ghostview/script does is to convert between several formats, including
eps, tif, dxf, pdf, jpg, bmp, to name a few.
David
*jmorris
Post 7 of 33
Re:
11-01-2001 11:42 PM in reply to: *Veilleux, Mike
>The main thing
And this is something that Acrobat will NOT do,
correct?
If yes... that gives Ghostview a major advantage right
there, doesn't it?
*Renaud, David
Post 8 of 33
Re:
11-01-2001 11:43 PM in reply to: *Veilleux, Mike
Don't know, like I said I have only used the Reader. I don't know at all
what a full version of Acrobat will do...
*jmorris
Post 9 of 33
Re:
11-02-2001 12:01 AM in reply to: *Veilleux, Mike
Oh I see.
So .... do you "create" PDF files using Ghostview and
GhostScript then?
IOW.... what I am asking is... what do YOU do with
Ghost view and script?
And why not just buy full Acrobat?
*Renaud, David
Post 10 of 33
Re:
11-02-2001 12:08 AM in reply to: *Veilleux, Mike
Well, actually, I hardly ever use it. What I do use it for is to convert
eps files (exported from Autocad, plot device Postscript Level 1) to
pdf's for distribution to clients, et al. It does this just fine, but I
have one called 5D2PDF that is easier to use and does the same
(eps-->pdf).
Why not Adobe Acrobat? These are free...
David
Post to the Community
New Post
