AutoCAD 2000/2000i/2002 Archive (Read Only)
Message 1 of 8
gshaner
312 Views, 7 Replies
Changing Units
When I change my drawing units from Architectural Units to Decimal units, it changes back to Architectural units when I do a regen. Any help on this one???
7 REPLIES 7
Message 2 of 8
in reply to: gshaner
Try renaming the block ACAD_ZZ and then purge it.
Settings for units are not retained
http://support.autodesk.com/getdoc.asp?id=TS53217
AutoCAD Drawing Units revert to decimal values
http://support.autodesk.com/getdoc.asp?id=TS65525
Please, DO NOT send technical requests to me via private e-mail
Tracy Lincoln
Assistant Moderator, Autodesk Discussion Groups
Discussion Group Links:
Index: http://discussion.autodesk.com
Rules: http://discussion.autodesk.com/webx?groundrules
Product Support: http://support.autodesk.com/
Knowledge Base: http://support.autodesk.com/ViewAnswerworks.asp
Downloads: http://support.autodesk.com/Downloads.asp
Message 3 of 8
gshaner
Thanks Tracy I will try that now and let you know. I am sure it will work.
Thanks again!!!
George
Message 4 of 8
gshaner
I was having trouble renaming the acad_zz block, could you help me with that
Message 5 of 8
George,
You might want to delete the first PS layout if the block refuses to
purge.
D
Message 6 of 8
I am experiencing the same problem. We use ADT
3.3 and  autocad 2002 with the latest AEC Object Enabler loaded. Now
when we open ( with Acad 2002) a project that was originally set up to use
decimal units it switches the units to Architectural.
I was unable to purge the ADCADD_ZZ
block.
Changing the measurement variable to 1 has no
effect.
I saw some thing (technical doc # TS65039) about
changing the registry but I do not have that specific key.
Any assistance would be greatly
appreciated
Sam Molinaro
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
When
Message 7 of 8
> with that
I believe the block might be on the First Layout, (e.g.: Layout1)
RENAME
Select Blocks
Select the block ACAD_ZZ
Type in a new name (e.g.: PURGE_ME)
Click OK
PURGE[enter]Select Blocks > PURGE should now be listed
Tracy Lincoln
Message 8 of 8
gshaner
I had gone through the steps you gave me and I got hte block to be erased, in the layout. I changed my units to decimal saved the drawing and then re-opened it and my units came back as architectural and the ACAD_zz block came back. I have the same problem again.
