AutoCAD 2000/2000i/2002 Archive (Read Only)
Cannot open multiple drawings in 2002
1 REPLY 1
155 Views, 1 Reply
I cannot open more than one drawing at a time in AutoCAD 2002. Is there a
command that may be turned off similar to Filedia or cmddia.
1 REPLY 1
Check what your SDI system varible is set for, also if you are using a
project based vertical (like Land Desktop) that is the way it work, one
drawing at a time.
Please, DO NOT send technical requests to me via private e-mail
Tracy W. Lincoln
Assistant Moderator - Autodesk Discussion Forums
Discussion Group Links:
Index: http://discussion.autodesk.com
Rules: http://discussion.autodesk.com/webx?groundrules
