AutoCAD 2000/2000i/2002 Archive (Read Only)
Can you turn an ellipse into a pline?
10 REPLIES 10
Message 1 of 11
369 Views, 10 Replies
Can you turn an ellipse into a pline and give it a thickness?
Dale Jarvis, Engineering Technologist
Gairns Santos Engineering Inc.
Ph. (250) 562-0330
Fax. (250) 562-0331
10 REPLIES 10
Message 2 of 11
Try re-drawing the ellipse as a polyline by setting
the variable "pellipse" to 1 (setvar "pellipse" 1).
Leo
Message 3 of 11
Sure in a round about way. WBLOCK all your Ellipses into a separate
drawing. Open the WBLOCKed drawing and SAVEAS r12 which doesn't support
ELLIPSE objects automatically converting them into Plines. Then Insert the
WBLOCKed drawing back into the original drawing.
Paul
"Dale Jarvis" wrote in message
news:5C30C29ACCE2B1D75CB402456DB4F52F@in.WebX.maYIadrTaRb...
> Ph. (250) 562-0330
> Fax. (250) 562-0331
Message 4 of 11
This old trick doesn't work in ACAD 2002, because you can't saveas r12
(dwg).
Juergen
Message 5 of 11
Dale,
Or try this lisp program. Converts a selection set of arcs, circles, splines
or ellipses to lwplines with a user defined number of vertices. Don't thank
me. I only tweaked it. Thanks goes to Andrzej Gumula.
;based on spline2poly.lsp by Andrzej Gumula - customization NG 9/27/02
;modified to include ellipses, circles and arcs - added undo
;needs A2k or above
(defun c:Curve2Pline (/ Fit SSet Count Delta Measure Pts Mark)
(defun *error* (Msg)
(cond
((or (not Msg)
(member Msg '("console break"
"Function cancelled"
"quit / exit abort"))))
((princ (strcat "\nError: " Msg)))
) ;cond
(UndoEnd)
(princ)
) ;end error
(vl-load-com)
;by John Uhden
(setq *acad* (vlax-get-acad-object))
(defun UndoBegin ()
(vla-StartUndoMark (vla-get-activedocument *acad*))
(defun UndoEnd ()
(vla-EndUndoMark (vla-get-activedocument *acad*))
;by Joe Burke with lotsa help
(defun SSAfterEnt (ent / ss* entlst)
(and
(setq ss* (ssadd))
(while
(setq ent (entnext ent))
(setq entlst (entget ent))
(if
(and
(not
(wcmatch (cdr (assoc 0 entlst)) "ATTRIB,VERTEX,SEQEND")
) ;not
(eq (cdr (assoc 410 entlst)) (getvar "ctab"))
) ;and
(ssadd ent ss*)
) ;if
) ;while
) ;and
ss*
) ;end
(defun MakePoly ()
(entmake
(append
(list
'(0 . "LWPOLYLINE") '(100 . "AcDbEntity") '(100 . "AcDbPolyline")
(cons 6 (vla-get-linetype Obj)) (cons 62 (vla-get-color Obj))
(cons 8 (vla-get-layer Obj)) (cons 90 (length Pts))
(if (vlax-curve-isclosed Obj) (cons 70 1) (cons 70 0))
(mapcar '(lambda (x) (cons 10 x)) Pts)
);end MakePoly
(defun StatLayer (Name Id)
(/= Id
(logand Id
(cdr (assoc 70 (entget (tblobjname "layer" Name))))
);end StatLayer
(UndoBegin)
(setq Mark (entlast))
(princ "Select circles, arcs, ellipses or splines: ")
(cond
((setq SSet (ssget ":L" '((0 . "SPLINE,ELLIPSE,CIRCLE,ARC"))))
(while (not (and (>= Fit 3) (<= Fit 500)))
(initget 7)
(setq Fit (getint "\nEnter number of segments [3 - 500]: "))
) ;while
(repeat (setq Count (sslength SSet))
(setq Count (1- Count)
Obj (vlax-ename->vla-object (ssname SSet Count))
Delta (/ (vlax-curve-getdistatparam Obj
(vlax-curve-GetEndParam Obj)) Fit)
Measure 0.0 Pts nil)
(repeat (1+ Fit)
(setq Pts (cons (vlax-curve-getpointatdist Obj Measure) Pts)
Measure (+ Measure Delta))
);end repeat
(cond
((StatLayer (vla-get-layer Obj) 4)
(MakePoly)
(vla-delete Obj))
);end cond
);end repeat
(T (prompt "\nCurves not selected "))
) ;cond
(cond ((> (sslength SSet) 0)
(princ (strcat "\nNumber of curves converted: "(itoa (sslength SSet))))
(sssetfirst nil (SSAfterEnt Mark))) ;select
) ;cond
(*Error* nil)
(princ)
);end
> Ph. (250) 562-0330
> Fax. (250) 562-0331
Message 6 of 11
R12DXF is just fine, which you can INSERT.
Dean Saadallah
http://www.pendean.com
Expanded Links Page
http://www.pendean.com/lt/links.htm
"Jürgen Palme" wrote in message
news:3DA7D0B0.E51DE679@debitel.net...
saveas r12
> (dwg).
> Juergen
separate
doesn't support
Then Insert the
Message 7 of 11
OK, I wrote "you can't saveas R12 (dwg !!)". The problems if you use the
dxf-export/-import are
- the drawing must not include 3D-Solids
- you can't use dxfin in an existing drawing (e.g. you can't follow the
steps described by Paul Li but have to export/import the whole drawing)
... or is it possible and I'm not aware of this?
Juergen
> Dean Saadallah
> Expanded Links Page
Message 8 of 11
"Dale Jarvis" a écrit dans le message de news:
A small LISP which does the trick at
http://www.afitec.com/Support/epaissir.php
(o)-(o)
---ooO---(_)---Ooo--------------------------
Message 9 of 11
You cannot do that because a Pline cannot take the shape of an ellipse, this
is simply mathematicaly impossible...
This is why the Offset command does'nt work on an ellipse and instead
creates a Pline approximately the shape of the Ellipse.
Using a very small offset amount like 0.00000000001 you can offset your
ellipse and turn it into a Pline, then apply a thickness with the pedit
command. The small Lisp I advise you in my other reply to your message just
do that.
(o)-(o)
Message 10 of 11
To quote Paul Li's post:
"WBLOCK all your Ellipses into a separate drawing. Open the WBLOCKed
drawing and SAVEAS r12 which doesn't support ELLIPSE objects automatically
converting them into Plines. Then Insert the WBLOCKed drawing back into the
original drawing."
What 3D Solids, we are talking about Ellipses?
INSERT command let's you pick DWG or DXF, no need for DXFIN command (which
is OPEN command BTW). Look it all up in HELP in R2002.
Dean Saadallah
Expanded Links Page
news:3DA92F5B.A1371119@debitel.net...
> Juergen
> > Dean Saadallah
> > Expanded Links Page
Message 11 of 11
I knew it: there was a black hole in my brain 😞
I was not aware that you can insert DXF-files too.
Thanks for correcting me.
Juergen
