Woops, I just rememberd that I think Autodesk took Whip off of their web
site, but replaced it with "Autodesk Express Viewer". I imagine it is
basically the same to use in this regard.
Dreamcad
Gene Marchetto
973-728-3928
dreamcad@optonline.net
"Eugene Marchetto" wrote in message
news:C0E8A79023C252BE4E2A01376F2CBBBD@in.WebX.maYIadrTaRb...
> If you have the Whip plug in from Autodesk (free), you can insert it as an
> object in Power Point. Select "Tools - Objects - Autodesk Whip! Control".
> Once the control is in Power Point, you can move it and resize it to
suite.
> To get your DWG image in the control, right click on it, and a properties
> box should come up. Then you can select the 'StreamName' property and
type
> in the full path and name of the dwf file. Unfortunatly that propertie
does
> not let you browse for a file, you must fully type it in. The advantage of
> using a DWF is you can actually pan around the drawing and turn layers
> off/on, and other things like that. Could make the presentation more
> dynamic.
> Hope this helps.
> Dreamcad
> Gene Marchetto
> 973-728-3928
> "eric coogan" wrote in message
> news:75013E29A8926CB4426CC50F143CDAD9@in.WebX.maYIadrTaRb...
> > My Question-
> > Does anybody know if it is possible to insert an autocad drawing into
> power
> > point and if so what format would it need to be in etc-dwf, dwg. My boss
> is
> > giving a presentation and would like to include a set of drawings into
his
> > power point presentation. Any help or suggestion would be greatly
> > appreciated.
> > Thanks in advance!!!!!!
> > Eric Coogan
> > Innovative Refrigeration Systems
> > 373 Mt Torrey Rd
> > Lyndhurst, Va. 22952
> > 540-941-1999-main office
> > 540-941-1994-direct line
> > 540-941-1997- Fax
> > E-mail eric@ammoniarefrigeration.net
