AutoCAD 2000/2000i/2002 Archive
Member
robertthen
Message 1 of 2 (177 Views)
Can't delete faces
177 Views, 1 Replies
10-27-2001 12:14 AM
Using autocad 2000i and trying to delete faces on a simple cube. I get the error "Modeling Operation Error:
Gap cannot be filled."
What is the problem. This should be a simple operation.
Can anyone help with this issue?
Thank you
Command: _solidedit
Solids editing automatic checking: SOLIDCHECK=1
Enter a solids editing option [Face/Edge/Body/Undo/eXit] : _face
Enter a face editing option
[Extrude/Move/Rotate/Offset/Taper/Delete/Copy/coLor/Undo/eXit] : _delete
Select faces or [Undo/Remove]: 1 face found.
Select faces or [Undo/Remove/ALL]:
*Skene, Tim
Message 2 of 2 (177 Views)
Re: Can't delete faces
10-28-2001 12:17 AM in reply to: robertthen
When you delete a face, the solid modeling software must be able to extend
or fill in the adjacent faces to make a complete, closed solid afterwards.
For example, you can delete a through hole by deleting the inside
cylindrical face, or delete a fillet by deleting all the curved faces so the
adjacent flat faces join together.
But if you try to delete a face from a cube, what are you expecting to get?
If you couldn't do it on a real piece of material, the software certainly
won't be able to.
Tim Skene
PRO Menu - The Productivity Toolbox for AutoCAD
www.multicim.com/pmenu.html
Post to the Community
New Post
Announcements
Are You Going To Be @ AU 2014? Feel free to drop by our AU topic post and share your plans, plug a class that you're teaching, or simply check out who else from the community might be in attendance. Ohh and don't forgot to stop by the Autodesk Help | Learn | Collaborate booths in the Exhibit Hall and meet our community team if you get a chance!
