AutoCAD 2000/2000i/2002 Archive (Read Only)
Can't delete an OLE object
3 REPLIES 3
6223 Views, 3 Replies
I have an OLE object in my drawing and I can select it to delete it or move it and the layer is not locked.
3 REPLIES 3
What comes up if you RMB over it.
Hi Marcel,
Treat it like a proxie that you can't delete, isolate it on it's own layer and Wblock everything else out. MS and PS separately and after successfully doing so, delete the original drawing and rename the Wblocked version back to the original name. GL
d0_0ver
select it (you have to click on the bounding box or select with a window), right click, select clear
