This sounds like it is a document management issue. You can have this work
seamlessly if it is programmed and set up to do so. A small system can be
set up (programmed) that will autonumber the titleblocks when needed.
If you need any help, you can contact me via phone or e-mail.
Good Luck!
Dreamcad
Gene Marchetto
973-728-3928
dreamcad@optonline.net
"Sam" wrote in message
news:0C1C5964D8E7D90E33031D0C2E9964B0@in.WebX.maYIadrTaRb...
> I have a problem in which I need to number about 300 drawing files on a
> titleblock as sheet x of 300. The problem is that the number of sheets
will
> most likely change numerous times, and I can't afford to manualy update
this
> numbering every time that it does. Someone told me that they thought
there
> was a way to link an excel file to do this. Can anyone explain this
process
> or suggest a better idea?
> Thanks,
> Sam
