AutoCAD r14 as well as r2000i will import .cal files as a raster image. You
will need a conversion software to convert to vector file. Draftsman Plus 32
will convert this type as well as other raster types (used it at last job
for a while). It has a lot of settings but with some trial and error you
will find a good result. Do web search for Draftsman plus 32 and down load
the demo. Good luck
Sean
"Pat Bjork"
wrote in message
news:5573B4719270F1132232253FF66C7C0D@in.WebX.maYIadrTaRb...
> I just recieved 40 *.cal files. Is there any way to convert these into
> either *.dxf or *.dwg files?
> Thanks in advance,
> Pat
