AutoCAD 2000/2000i/2002 Archive (Read Only)
.cal file convert to .dwg file
4 REPLIES 4
4849 Views, 4 Replies
I just recieved 40 *.cal files. Is there any way to convert these into
either *.dxf or *.dwg files?
Thanks in advance,
Pat
4 REPLIES 4
You need to get a Vertical Market version of AutoCAD that can import .CAL
files: I think AutoCAD MAP might work. Check out the website:
http://www.autodesk.com/products
Dean Saadallah
www.pendean.com
"Pat Bjork" wrote in message
news:5573B4719270F1132232253FF66C7C0D@in.WebX.maYIadrTaRb...
> Thanks in advance,
> Pat
AutoCAD r14 as well as r2000i will import .cal files as a raster image. You
will need a conversion software to convert to vector file. Draftsman Plus 32
will convert this type as well as other raster types (used it at last job
for a while). It has a lot of settings but with some trial and error you
will find a good result. Do web search for Draftsman plus 32 and down load
the demo. Good luck
Sean
> Thanks in advance,
> Pat
Thanks Dean and Sean. We do have CAD overlay. It will do what I need. Thanks
again for you help.
Pat
Your welcome. Goodluck.
Sean
news:BB09854F21711DA5ECA79975C0DDFE4C@in.WebX.maYIadrTaRb...
> again for you help.
> Pat
