Ave wrote:
> Tracy
> Would you explain more the MOVEBAK & save w/ 2 QSAVES and why
> ISAVEPERCENT should be 0?
> I work from a drive that is share and not in my computer, so each time
> I save the BAK goes into a TEMP folder, right? in my C: drive, or
> where? I want to know by doing MOVEBAK and create a folder in my C:
> drive will the share drive will keep another BAK dwg? Thank you
MOVEBAK does just that...
Saving with 2 QSAVES just makes the BAK=DWG except for the extension
ISAVEPERCENT being set to zero ensures every save is a full save (see
ISAVEPERCENT in the Help Files)
As for where your BAK gets moved to, if you have MOVEBAK you can specify
where the BAK file gets moved to, otherwise it is saved where the DWG
file is. So in your case MOVEBAK will move the BAK file to your C:\ and
leave the DWG file on the shared drive. There will only be one BAK and
one DWG... you could always leave them on your shared drive and copy
them to another location.
DO NOT send technical requests to me via private e-mail
Tracy Lincoln
Assistant Moderator, Autodesk Discussion Groups
Discussion Group Links:
Index: http://discussion.autodesk.com
Rules: http://discussion.autodesk.com/webx?groundrules
Product Support: http://support.autodesk.com/
Knowledge Base: http://support.autodesk.com/ViewAnswerworks.asp
Downloads: http://support.autodesk.com/Downloads.asp
___________________________________________________________________
This communication and any files or attachments transmitted with it
may contain information that is confidential, privileged and exempt
from disclosure under applicable law. It is intended solely for the
use of the individual or the entity to which it is addressed. If you
are neither the intended recipient, nor the employee or agent
responsible for delivering the message to the intended recipient, you
are hereby notified that any use, dissemination, or copying of this
communication is strictly prohibited. If you have received this
communication in error, please promptly notify the sender by reply
e-mail, and then destroy the original and all copies of this
transmission.
