Show only
Search instead for
When I try to measure the side of a 3d object in isometric view, I can't see the final measurement. I know it is simply a system variable, I just can't figure out which one.
Thank u
daf
Most likely the dimension/text style you are using is set up for display in
plan view. You will need to create a dimension/text style that is
orientated for your isometric view.
Chip Harper
Member of the AutoDesk Discussion Forum Moderator Program
