AutoCAD 2000/2000i/2002 Archive (Read Only)
Autocad 2002 (property box shows no selection when i select a line)
7 REPLIES 7
Message 1 of 8
1126 Views, 7 Replies
Autocad 2002
I am having problems with the properties box. When i select a line the properties box shows "no selection" therefore i cant get any of the properties of the item selected. I am not exactly sure what I did but I bet it is a pretty simple fix. Please help! Thank you.
I have attached a screen shot so that you can see what i am talking about. Edited by: grind77 on Dec 11, 2008 7:36 PM
7 REPLIES 7
Message 2 of 8
Check your PICKFIRST and PICKADD variables. Should be set to 1.
Jason Rhymes
3D Solid Power Toys
including Multi Solid
Stretch
href="http://www.acadianagraphics.com">http://www.acadianagraphics.com
Autocad
2002 I am having problems with the properties box. When i select a line the
pretty simple fix. Please help! Thank you. I have attached a screen shot so
7:36 PM
Message 3 of 8
Both the PICKFIRST and the PICKADD variables were set to 1.
Message 4 of 8
Thank you Jason. But unfortunately that was not it. Both the PICKFIRST and the PICKADD variables were set to 1. Can you think of anything else?
Message 5 of 8
You ran a Windows Registry Cleaner on your PC and it wiped out Properties
command. A reinstall of AutoCAD is the only fix (don't forget to fully patch
it afterwards, and stop using a Windows Registry Cleaner that does not have
the ability to stay away from AutoCAD entries).
Dean Saadallah
http://LTisACAD.blogspot.com
Message 6 of 8
Thanks all for your help!
Message 7 of 8
before reinstalling Acad try this reg cleaner.
It's old, free, and from Microsoft. I've used it many times on many
computers always great results.
http://majorgeeks.com/download458.html
good luck
wrote in message news:6090405@discussion.autodesk.com...
Message 8 of 8
I m Facing same problem please tell me the solution.
