AutoCAD 2000/2000i/2002 Archive
Active Member
jimschmidt
Message 1 of 3 (274 Views)
autocad 2000 won't recognize digitizer/pointing device
274 Views, 2 Replies
06-03-2009 10:32 AM
After installing my sumagraphics digitizer and calcomp driver (tweser2kxp) I am unable to configure my tablet. When I enter the "tablet" command it says "your pointing device cannot be used as a tablet".
I can see that my digitizer works to the point that the puck moves the cusror on the screen.
Please help.
Jim
*Dean Saadallah
Message 2 of 3 (274 Views)
Re: autocad 2000 won't recognize digitizer/pointing device
06-03-2009 11:25 AM in reply to: jimschmidt
The error message means your driver is not being recognized as one belonging
to a tablet. AutoCAD will not fix this, you need a driver that AutoCAD can
use as a tablet, not a mouse (why it moves on screen, because Windows sees
it as a mouse driver).
Dean Saadallah
http://LTisACAD.blogspot.com
*Joel
Message 3 of 3 (274 Views)
06-03-2009 11:27 AM in reply to: jimschmidt
Go to "Options", in the "System" tab, look for the section called "Current
pointing device" and change it from "Current system pointing device" to
"Wintab Compatible Digitizer...".
Also, if you still have a mouse connected as well, make sure that "Accept
input from:" below that is set to the "Digitizer and mouse" option. The
"Digitizer only" option will make nothing work.
Post to the Community
New Post
Announcements
Do you have 60 seconds to spare? The Autodesk Community Team is revamping our site ranking system and we want your feedback! Please click here to launch the 5 question survey. As always your input is greatly appreciated.
