If you have xrefs in the drawing, open them and audit them as well.
After your audit, use purge command...under "blocks" you might see one
prefixed "audit_...." or some such, purge that (and all blocks if any there)
and "save" and "audit" again.
These might help you out.
"Vincent Hunter" wrote in message
news:DA55D3210EDBC7C51B4C5DD377EEDCEC@in.WebX.maYIadrTaRb...
> DXF Name Current Value Validation Default
> AcDbHatch(8487) Boundary Missing a Reactor Remove
Associativity
> Hi all,
> When I Audit one of our elevation drawings, I get twenty-five messages
> similar to the one above. Then it states:
> 216 Blocks audited
> Pass 1 18280 objects audited
> Pass 2 18280 objects audited
> Pass 3 40700 objects audited
> Total errors found 25 fixed 25
> When I type AUDIT again, the 25 errors it stated were fixed were, alas,
not
> actually fixed and are still there to cause problems. I copy-clipped the
> file out into a new file and the errors were still unfixable but
auditable.
> Any thoughts? I need help badly.
> Thanks,
> Vincent M. Hunter, AIA
