AutoCAD 2000/2000i/2002 Archive (Read Only)
ASSOCIATIVE DIMENSION ON 3D OBJECTS
11 REPLIES 11
Message 1 of 12
johnysadot
323 Views, 11 Replies
Hi all,
Does the dimensions update with 3d geometry as 2d?
I tried with a square extruded and made dimensions on x, y and z axis, changing ucs to top and front. When I modified the solid with Extrude Faces the dimensions doesn't update. Is here something wrong? I need to change a variable?
Thanks in advance!
Johny D.
11 REPLIES 11
Message 2 of 12
in reply to: johnysadot
Quoting Shaan Hurley:
Here is a list of objects that do not currently support trans-spatial
associative dimensioning (what a mouthful). You will also get an alert
on
the command line when you attempt to dimension these objects from
paperspace.
* All dimension objects
* Leaders
* Tolerances
* Multi-lines
* Any min-inserted block
* Solids
* Traces
* 3D Faces
* Polygon mesh vertices
* Polyline mesh vertices
* Polyline meshes
* Polygon meshes3D Face records
* Viewports
* Hatches
* Mirrored or non-uniformly scaled block references
* Images
DO NOT send technical requests to me via private e-mail
Tracy Lincoln
Assistant Moderator, Autodesk Discussion Groups
Discussion Group Links:
Index: http://discussion.autodesk.com
Rules: http://discussion.autodesk.com/webx?groundrules
Product Support: http://support.autodesk.com/
Knowledge Base: http://support.autodesk.com/ViewAnswerworks.asp
Downloads: http://support.autodesk.com/Downloads.asp
johnysadot wrote:
> Hi all,
> Thanks in advance!
> Johny D.
Message 3 of 12
galinav
I didn't know that associative dimensioning doesn't working with solids and tried it, of course, without success.
But something strange happened after this: When I changed the UCS, and made a new dimension in the new UCS, all old dimensions were updated to the new UCS and became zero. How can I prevent this? It's awful, I had to make all my dimension again, starting from the beginning .
Regards: Galina
Message 4 of 12
I don't think you are aware of situation where there is no alert when the
dimension is not associative. I just repeated the test to make certain I was
correct... if you dimension from a "legal" entity to part of a dimension
line, (i.e. snapping to what you think is the end of a line, but there is a
dimension in modelspace laying on the same line, so it is not visible) the
dimension will be created without warning. That dimension will show an
incorrect value, since it is not scaled for the viewport.
Still, even the situations where there is an alert... it occurs at the
command line where it will be VERY unusual for a user to notice.
DON"T USE PAPERSPACE DIMENSIONS, YOU ARE RISKING RELEASING INCORRECT
DRAWINGS!
Joe Dunfee
"Tracy W. Lincoln" wrote in message
news:3CBF07A8.167A3274@iroquois.com...
> on
> paperspace.
> * Leaders
> * Tolerances
> * Multi-lines
> * Solids
> * Traces
> * 3D Faces
> * Polyline meshes
> * Viewports
> * Hatches
> * Images
> Tracy Lincoln
> johnysadot wrote:
> > Hi all,
> > Thanks in advance!
> > Johny D.
Message 5 of 12
Joe,
Could you please provide steps where the transpatial dimension is not
associated and there is no alert at the command line? I tried the case you
mention and the dimension was still associated. What would you suggest an
alert or other notification?
Sincerely,
Shaan Hurley
Autodesk, Inc.
"Joe D." wrote in message
news:3C916B5473386A1B89B290DB35399A36@in.WebX.maYIadrTaRb...
the
Message 6 of 12
I think there are several ways to recreate the problem since there are
many kinds of entities which aren't compatible with the transpacial
dimensions, but here is the method I most recently recreated...
- Draw a pbox in modelspace.
- While still in modelspace place a dimension internally to the box, so
that the dimension extension line overlaps the pbox.
- Switch to paperspace, create a paperspace dimension and deliberately snap
to the end of one of the dimension extension lines for one of the points.
The dimension placed gives the paperspace length, and there is no warning
message of any kind.
For creating a warning, whatever it is, it must absolutely grab the users
attention. Probably a warning box popping up is the best choice. No one
ever wants to create a dimension that shows the wrong value, so it should be
difficult to do so.
Even if you have memorized the list of problem entities, the only way to
discern if the object is an acceptable entity to dimension, is to examine
the objects properties first to compare it to your list of problem
entities.... not exactly a fluid workflow. More likely, the user will know
nothing about your problem entity list and will dimension them, thinking the
transpacial dimensions will work... they are going to be fooled and
potentially release a drawing with bad dimensions. In the case of
dimensioning things like 3-D faces there will be a warning, but the warning
message is on the command line, where it will probably not be noticed.
In our case, a warning box won't make transpacial dimensions usable. The
majority of the entities in our drawings are on the list of entities that
the transpacial dimensions don't like. So, I can't think of an easy fix for
that.
But, just knowing that warning is there will make the program more trust
worthy. Printing out bad data is VERY TROUBLESOME! One thing which
Autodesk should be vigilant to guard against.
Joe Dunfee
"Shaan Hurley" wrote in message
news:CF105FA5045B7871784E4A57AA06D338@in.WebX.maYIadrTaRb...
> Joe,
> Sincerely,
> Shaan Hurley
> Autodesk, Inc.
> the
Message 7 of 12
Joe,
I will agree we need to be clear if a clear error is made but in some cases
it is hard to guard against. The problem you are seeing in the steps you
listed with no warning was most likely due to not dimensioning to the solid
or the dimension but an origin point as that is what I seen when I performed
your instructions then looked at the dimension. Also why would you dimension
that way in both model and layout and also overlapping the solid as that
seemed odd to me. If I select to dimension to the dimension specifically I
get "Non-associative dimension created" at command line. There are many
other areas in AutoCAD and other CAD applications as well where due to the
complexity and varied usage the user needs to have some knowledge of what
occurs otherwise you could have GIGO (Garbage In Garbage Out). The in your
face alerts can cause frustration of users as well.
Sincerely,
Shaan Hurley
Autodesk, Inc.
news:95FA89F190C7800340CA88706D8B7EA7@in.WebX.maYIadrTaRb...
snap
be
> difficult to do so.
know
the
warning
The
for
> that.
> Joe Dunfee
> > Joe,
you
an
> > Sincerely,
> > Shaan Hurley
> > Autodesk, Inc.
when
> > the
Message 8 of 12
OK, I realize that dimensioning objects that already have modelspace
dimensions (although another user has run into this problem... it is not
just our office) The real-life situation where the error occurs is when the
dimension scale is so that the offset of the modelspace extension line is
very tiny.
Anyway, I just spent a few more minutes and was able to find another
method of creating the incorrect dimensions without a warning. I am sure
this situation will be much more common with other users.
- I opened an existing object. The object has a 3d-polyface mesh as well
as other entities like a 2-D polyline with a thickness.
- I go to a new layout tab, and accept the default view.
- I dimension the height of the object, by snapping to the endpoints of a
polyline with thickness, and one point on the polyface mesh.
The dimension created shows the paperspace distance, not the height of the
object. Here is a copy of the command lines immediately after creating this
dimension...
Command: ps PSPACE
Command: dim
Dim: vert
Specify first extension line origin or
Message 9 of 12
Joe,
It appears the dimension is not associated with the 3D Face just like
dimensions in prior releases except that now you are seeing this same
limitation transpatially more as you are trying it more often. Is this
correct?
Sincerely,
Shaan Hurley
Autodesk, Inc.
news:3BA4A060EC395316719BE18FF99D7D11@in.WebX.maYIadrTaRb...
the
> very tiny.
this
> dimension...
> Command: ps PSPACE
> Command: dim
> Dim: vert
Message 10 of 12
I am not certain what you are asking. My AutoCAD use has spanned
10,11,12, LTv2, and then jumped to LT'97, till I recently upgraded to the
Inventor Series with 2002.
I think the past problems I had with paperspace dimensions on LT'97 were
because of drawing file corruption, well... at least that is the Autodesk
theory. I also had some paperspace problems with earlier versions of
AutoCAD, so I wanted to be very careful with the transpacial dimensions.
I really considered using the old-style paperspace dimensions, using the
DIMLFAC variable. But, I am just so gun-shy about relying on them. My past
experience has taught me that I might come in one morning to print out a
drawing that was fine when I worked on it yesterday. I print out the
drawing and give it to the shop for production... but unknown to me, a few
of the dimensions (out of hundreds) have forgotten their DIMLFAC scale
factor and show a wrong value. Hopefully, the value shown will be obviously
wrong to the guy building it and they will ask me about it. But, I can
certainly see times it might not... i.e. what was 2'-1 3/4" now reads 2
5/8". The guy in the shop interprets it as 2 feet and 7/8" inches. After
all, he already know that AutoCAD will mess up the dimension display... "it
must have dropped that dash."
Unfortunately, I just don't see an easy fix for the program. To maintain
compatibility with the old "associative" dimensions, and the newer
"associative" transpacial dimensions, they come up with the new and improved
"SUPER DUPER ASSOCIATIVE" dimensions. Pretty soon, it will take an advanced
doctorate degree in AutoCAD dimensioning to figure it all out!
Joe Dunfee (not Joe Dunne)
news:6FC4CCC8824EE812F2FB51B7374BE0A1@in.WebX.maYIadrTaRb...
> Joe,
> correct?
> Sincerely,
> Shaan Hurley
> Autodesk, Inc.
Message 11 of 12
Joe,
I was referring to 3D Face objects not even associating with DIMASO based
dimension node points in past releases which is the same cause that you
cannot acquire the object transpatially. The new associative dimensioning
only works for entities that have been able in past releases to have a
dimension node associated. You should always check your drawings as
unfortunately the there are many ways to get bad dimensions of objects in
any CAD system until such time as computers have artificial intelligence. In
your specific case of 3D faces and the concern I would suggest just not
dimension from paperspace if you are concerned about missing errors.
Sincerely,
Shaan Hurley
Autodesk, Inc.
news:849F3AC95F826FA2C6D8C12D5CBF452B@in.WebX.maYIadrTaRb...
the
past
obviously
"it
maintain
improved
advanced
> > Joe,
> > correct?
> > Sincerely,
> > Shaan Hurley
> > Autodesk, Inc.
Message 12 of 12
I forgot to mention I will also discuss your specific concern with the
dimensioning team.
Sincerely,
Shaan Hurley
Autodesk, Inc.
news:FD16D44A107D2473DB9E9D88CF3BDCF2@in.WebX.maYIadrTaRb...
> Joe,
In
> Sincerely,
> Shaan Hurley
> Autodesk, Inc.
the
were
> the
> past
few
> obviously
After
> "it
> maintain
> improved
> advanced
> > > Joe,
> > > correct?
> > > Sincerely,
> > > Shaan Hurley
> > > Autodesk, Inc.
