AutoCAD 2000/2000i/2002 Archive
*Hurley, Shaan
Post 1 of 19
AIA Standards
104 Views, 18 Replies
05-24-1999 11:08 AM
Ed,
I am forwarding one your way via email. It was created by Robert Grandmaison
in R14.
Cheers,
Shaan Hurley
Autodesk Beta Programs
Edward G. Leaders wrote in message <7ic1vk$9461@adesknews2.autodesk.com>...
>This may seem like a foolish question, but I'm gonna ask it anyway.
>Does anybody out there have a single drawing that has ALL of the possible
>layer names on it, that are currently supported by the AIA standard??
>If so, could you e-mail me a copy?
>Thanks
>Ed Leaders
>Champion International Paper
>Sartell, MN USA
>leadee@champint.com
*Grandmaison, Robert
Post 2 of 19
Re: AIA Standards
05-24-1999 11:36 AM in reply to: *Hurley, Shaan
Hey, I was gonna send it to him! ; )
Cheers,
Robert Grandmaison
BTW: Why don't you post it to the customer files NG Shaan?
Shaan Hurley wrote:
> Ed,
> in R14.
> Cheers,
> Shaan Hurley
> >Thanks
> >Ed Leaders
> >Sartell, MN USA
> >leadee@champint.com
*Hurley, Shaan
Post 3 of 19
Re:
05-24-1999 11:42 AM in reply to: *Hurley, Shaan
Excellent idea Robert. I will post it there for everyone.
Cheers,
Shaan Hurley
Robert Grandmaison wrote in message <37499C29.12F34BF8@mkmassociates.com>...
>Cheers,
>Robert Grandmaison
*Tanzillo, Tony
Post 4 of 19
Re: AIA Standards
05-24-1999 12:38 PM in reply to: *Hurley, Shaan
I don't know if it has them all, but if you download
LAYORG.ZIP from the customer-files newsgroup, it will
display a tree view that contains over a thosand layers
from the original AIA layer standard.
> Thanks
> Ed Leaders
> Sartell, MN USA
> leadee@champint.com
/* Tony Tanzillo Design Automation Consulting */
/* Programming & Customization for AutoCAD & Compatibles */
/* tony.tanzillo@worldnet.att.net */
/* http://ourworld.compuserve.com/homepages/tonyt */
*McDonough, Mark
Post 5 of 19
Re:
05-25-1999 08:23 PM in reply to: *Hurley, Shaan
Tony Tanzillo wrote in message <3749AABA.3E5954D3@worldnet.att.net>...
1000? We adapted the original AIA layer standards into our own
implementation of the standard, utilizing "layer groups". No drawing ever
has more that a couple dozen layers based on such a grouping scheme. I
never counted the # of layers in the AIA standard, but "over a thousand
layers" sounds insane to me. The AIA standard has officially changed
recently, although our firm has flat out rejected the change, which goes to
variable-length layer names, whereas the previous system of fixed-length
layer names, modifiers, prefixes and suffixes, etc., all seemed to make
sense. The new "less structured" format doesn't make any sense at all.
I see no reason for over 1000 layers except perhaps for the terminally anal
(many Architects are included here, myself included!).
Mark McDonough
antennaria@aol.com
*Harder, Brian
Post 6 of 19
Re:
05-26-1999 08:04 AM in reply to: *Hurley, Shaan
I may be completely wrong here, but I think that the AIA layering scheme is
as much a methodology, as it is a once and for list of layers. You could in
fact use only a dozen layers, and still be in complience with the AIA layer
scheme, or, if you really needed more, (hope I never work at a firm that
uses 1000 layers), you could create completely unique layers, that still
conform to the AIA layer naming convention.
Brian Harder
President
Professional AutoCAD User's Group
http://www.paug.org
Mark McDonough wrote in message <7ifp4a$h5u14@adesknews2.autodesk.com>...
>Mark McDonough
>antennaria@aol.com
*Tanzillo, Tony
Post 7 of 19
Re:
05-27-1999 12:57 AM in reply to: *Hurley, Shaan
Mark - Do you understand the difference beween a drawing
with 'over 1000 layers', and a layer standard that uses
a naming convention that can have an unlimited number of
layers, depending on the level of granularity that one
wants or needs?
The fact is that rarely are there cases where even a
small fraction of the potential number of layers that
are defined by a given standard would be needed.
The number of layers one may require on a large hospital
project could approach several hundred with ease, but I
would not expect the same would be the case in a small
residential project.
> Mark McDonough
> antennaria@aol.com
*Tanzillo, Tony
Post 8 of 19
Re:
05-27-1999 12:58 AM in reply to: *Hurley, Shaan
Exactly! It does not define a finite list of layers, only
the convention and methodology by which one goes about
naming them.
*McDonough, Mark
Post 9 of 19
Re:
05-27-1999 02:56 PM in reply to: *Hurley, Shaan
Of course I understand the difference. In part I responded to your first
message declaring that the AIA standard "view" of layers contains over a
1000. The phrase "level of granularity", as a controlling force in the
number of layers needed in any given drawing, is exactly the right point to
make. In our opinion, the level of granularity suggested by the AIA
layering scheme was way too dense or too finite, needlessly making available
too many layers. We loosely adopted a less granular view of layer usage
(translation: considerably fewer layers).
We also understand that the AIA standard puts forth a syntax or layer naming
methodology as Brian suggested, by which new layers can be created that
conform to the standard. Our adoption of a simplified AIA layering standard
does exactly this.
Mark McDonough
mmcdonough@sasaki.com
http://www.sasaki.com
news:374CFAE6.B8D92733@worldnet.att.net...
> wants or needs?
ever
to
anal
> > Mark McDonough
> > antennaria@aol.com
*Gesner, Rusty
Post 10 of 19
Re: AIA Standards
05-31-1999 11:19 PM in reply to: *Hurley, Shaan
I view the AIA standards as a consistent and easily
decipherable scheme for layer naming this is intended to be
extensible, not all-inclusive.
> Thanks
> Ed Leaders
> Sartell, MN USA
> leadee@champint.com
B. Rustin (Rusty) Gesner, AIA -- (rusty@group-a.com)
Group A -- AutoCAD Expert & Author -- http://www.group-a.com
Group Mackenzie -- CAD Manager -- (opinions expressed are
mine only)
Post to the Community
New Post
Announcements
Are you interested in helping shape the future of the Autodesk Community? To participate in this brief usability study, please click here. Your time and input is greatly appreciated!
