well, I agree that doing a from scratch install of Everything on a new box
will take some time, it can still be minimized by the use of the same drive,
common folder names, special folders for customization, and profiles. Try it
next time you have to do an upgrade, you'll like it 🙂
dave.ddp
"Marshall E. Caudle" wrote in message
news:C195AEFA1B78A7C57FDF152BC72F4712@in.WebX.maYIadrTaRb...
> Thanks for the tip - I didn't think of doing it that way. I'll have to
try
> that next time I set up a computer.
> One of my problems is that I usually put off a major software upgrade
until
> I upgrade my computer so at that point I'm usually starting from scratch.
> When I installed A2ki I upgraded from a 300mz with 256 RAM to a Ghz with
512
> RAM and the buss on the boards was also much faster than my old machine.
> Ghz boards and processors are now down in the $300 dollar range. I try to
> stay a generation or two behind in hardware because the prices drop
> drastically once the new ones are put on the market and even the old ones
> are faster than I can think. I hope with the new dual processor boards
now
> out that the 1.8Ghz boards and processors will take a big drop.
> Semper Fi
> Marshall Caudle
> "Dave Jones" wrote in message
> news:5C34FCDE9BE621CD8EF95759DE53DE8F@in.WebX.maYIadrTaRb...
> > just out of curiousity, why would you have to reinstall programs like
> > QuikPik and ToolPac (both of which I use) when you reinstall Acad? I
have
> a
> > folder called Acad which I always install AutoCAD to which has non Acad
> > installed folders for my lisp/vba routines, plotter setups, bitmaps,
etc.
> I
> > save a profile before I uninstall, uninstall acad but leave my custom
> > subfolders, clean the registry with System Mechanic, restart the
computer,
> > install the upgrade to the Acad folder, and restore my profile which
> reloads
> > everything. 10 to 15 minutes max start to finish...honest 🙂
> > dave.ddp
> > "James Wedding, E.I.T." wrote in message
> > news:B2FABC85C5D26CD2221CE9776E26B7DE@in.WebX.maYIadrTaRb...
> > > What stuff? Toolpac, Quikpik, Plot logging, acad.dvb, plot setups,
> > > templates, preferences, acaddoc.lsp, etc. I've got about 20 things I
> > change
> > > after the install is supposedly complete. I'm with Marshall...the
> install
> > is
> > > fast, it's all the tweaking that takes so long. Even with profiles and
a
> > > check list, I still allow two hours minimum to do a clean install of
LDD
> > and
> > > "stuff."
> > > IT Manager
> > > Jones & Boyd, Inc.
> > > Dallas, Texas
> > > jwedding@NOSPAMjones-boyd.com
> > > Remove NOSPAM from e-mail for reply.
