AutoCAD 2000/2000i/2002 Archive (Read Only)
rsteiner
1934 Views, 4 Replies
acad.pat
When I enter bhatch in the command line I keep getting the following message.
c:\program files\autocad 2000i\support\acad.pat Can't open file
This is followed by
Unable to open file: acad.pat, error = 1
Then
No standard pattern available
Error in reading the pattern file.
I've looked up the acad.pat file and it is there. Any suggestions.
4 REPLIES 4
in reply to: rsteiner
Missing or corrupt ACAD.LIN file ... just like the error says. Be sure
ACAD.LIN is in the path defined for your installation.
___
"aflores" wrote in message
news:f153e10.-1@WebX.maYIadrTaRb...
message.
> This is followed by
> Then
Duh ... that's ACAD.PAT, of course, not ACAD.LIN.
___
"Paul Turvill" wrote in message
news:017EE59CEC418A6D21987EC86733CBB4@in.WebX.maYIadrTaRb...
Josh1M
As you have just noticed, nobody helped you with your problem. I had the same thing happen to me a few minutes ago and had to figure out a solution myself. you need to do the following: open AutoCAD, type in opions, go to the Files tab, click on the + next to Support file search path. Look to see if one of the files listed is.....example........ C:\Documents and Settings\user name\Aplication Data\Autodesk\AutoCAD 2006\R16.2\enu\support. that is the file path of your hatch patterns. if it isn't there do this: click on Add, and then enter the entire file path for the location of the support folder containing your acad.pat file, and click OK............good luck.
idearchitects
Thank you! I had the same problem and fixed it in a minute with your advise.
