ASE, SQL, OLE, ADE
*Wang, Weslley X
Post 1 of 4
How I can know if I connect to database in LISP
134 Views, 3 Replies
01-12-2000 11:17 AM
Hello:
I am working with a Map Util project. I try to make a Link Path.
before I do it, I have to check if the same name Link Path existed. If
there are no same name Link Path existed, I will create one. when I
tested my code, I found it crashed a lot. because there so many case I
can not determine:
a drawing with database connected or not, a drawing with database
attached or not, If I connect a database and then disconnect it, the
condition is not like one before I connect the database.
Here is my code:
(defun connect (table keyfield lpn)
(cond (trace_functions (princ "\nSubroutine: Connect")))
(setq connectionok nil)
(setvar "cmddia" 0)
(princ "\nVerifying database connection to the ")
(princ table)
(princ " table. Please wait.")
;; The following segment was added on August 16 to CONFIRM connection
to a database table.
(if (member (list table keyfield lpn) connectionlist)
(progn ;; If the table we are searching for is already in the list
of connected tables
(setq sqlstr (strcat "SELECT * FROM " odbcschema "." table))
(if (null session)
(setq session (asi_connect odbcname username passwrod))
) ;_ end of if
(setq statement (asi_prepare session sqlstr))
(if statement ;If the statement creation is NOT valid, go through
the connection process.
(progn (setq connectionok T) (asi_deallocstm statement))
) ;_ end of if
) ;_ end of progn
) ;_ end of if
(if (not connectionok)
(progn
(setq dostatus (ase_dostatus (ase_lppath lpn))) ;Set the database
object status
(if (= dostatus 18) ;If the status is not confirmed...
(progn (command "aseadmin" "environment" odbcname "exit")
(setq dostatus (ase_dostatus (ase_lppath lpn))) ;Update the
database object status
(if (= dostatus 18) ;If the status is still unconfirmed...
(progn (princ "\nPerforming full connection to environment ")
(princ odbcname)
(command "aseadmin" "environment" odbcname "options" "connect"
username password "exit" "exit")
) ;_ end of progn
) ;_ end of
) ;_ end of progn
) ;_ end of
(cond ;;
((and (= (substr (ase_docurrent) 1 (strlen odbcname)) odbcname)
(null dostatus))
(princ (strcat "\nCreating Link Path Name " (strcase lpn)))
(command "aseadmin" "catalog" "CAD" "schema" odbcschema
"table" table "options"
"link-paths" "new" keyfield "" lpn "set" lpn
"exit" "exit" "exit"
) ;_ end of command
((null dostatus)
"connect" username password
"" "catalog" "CAD" "schema" odbcschema "table"
table "options"
lpn
) ;_ end of command
((= dostatus 10)
"exit" "Table" table "options" "link-paths"
"n" keyfield
"" lpn "exit" "exit" "exit"
) ;_ end of command
((< dostatus 14)
(command "aseadmin" "Table" table "options" "link-paths" "n"
keyfield "" lpn "exit" "exit" "exit")
) ;_ end of cond
) ;_ end of progn
(progn ;;
(if (and (= (substr (ase_docurrent) 1 (strlen odbcname)) odbcname)
(null dostatus))
(progn ;;
lpn
) ;_ end of command
) ;_ end of progn
) ;_ end of if
) ;_ end of progn
) ;_ end of
(if (null session)
(setq session (asi_connect odbcname username password)) ;Connect to
the ODBC connection.
) ;_ end of if
(if (not (member (list table keyfield lpn) connectionlist))
(setq connectionlist (append connectionlist (list (list table
keyfield lpn))))
) ;_ end of
(setvar "cmddia" 1)
(princ)
) ;_ end of function CONNECT
;; end of code
If you can help, thanks a lot
Weslley X Wang
I am working on Map 3, Windows NT 4. SP3 with Pentium Pro 200, 128 MB
memory,
*Fleming, Jon
Post 2 of 4
Re: How I can know if I connect to database in LISP
01-12-2000 02:37 PM in reply to: *Wang, Weslley X
I don't have much experience with LPNs and Displayable Attributes.
However, you might find DBL202.ZIP from http://www.cadalog.com useful (in
the portions of your program where you execute SQL statements directly).
jrf
Member of the Autodesk Discussion Forum Moderator Program
In article <387CD32C.9FECD3BB@autodes.com>, Weslley X Wang wrote:
> Hello:
> can not determine:
Re:
02-10-2000 07:43 PM in reply to: *Wang, Weslley X
Jon,
Once again, that web site is still showing a message that they are down with
hardware failures (2/10/00). Anyway you could post that file here somehow?
Maybe in teh Customer Files section?
Thanks! Dave Stein
"Jon Fleming" wrote in message
news:VA.00000b96.04ef44f9@fleming-group.com...
> ...you might find DBL202.ZIP from http://www.cadalog.com useful
*Fleming, Jon
Post 4 of 4
Re:
02-11-2000 04:27 AM in reply to: *Wang, Weslley X
OK.
jrf
In article <8800bg$seu2@adesknews2.autodesk.com>, Ds wrote:
> Jon,
> Thanks! Dave Stein
