ASE, SQL, OLE, ADE
ASE, SQL, OLE, ADE
Active Contributor
gshaner
Message 1 of 8 (89 Views)
Excel Spread Sheet into AutoCad
89 Views, 7 Replies
12-26-2002 06:12 AM
I am needing to import a spreadsheet into Autocad, and I am having troubles with it not showing the entire file. Can anyone help...
*Support, Autodesk
Message 2 of 8 (89 Views)
12-26-2002 07:43 AM in reply to: gshaner
Unfortunately Windows OLE does have limitations & you've run into one, &
there's nothing our applications can really do about it. In the
Knowledge Base at http://support.autodesk.com/enu/Homepage.asp, take a
look at the documents numbered TS32085 & TS21730 for further information
& a few suggestions for working around those limitations.
Jeff W. Heaton
Autodesk Product Support, Platform Technology Group
Discussion Q & A: <>
*Dotson, Terry W.
Message 3 of 8 (89 Views)
12-26-2002 12:00 PM in reply to: gshaner
Take a look at http://www.dotsoft.com/xl2cad.htm.
Terry
*Solomon, Semyon
Message 4 of 8 (89 Views)
12-26-2002 12:40 PM in reply to: gshaner
Besides Spanner, which works very well, you can also do the following:
Select and copy the portion of the spreadsheet that you want to import into
AutoCAD. Go to your AutoCAD drawing, and under the Edit menu use Paste
Special. In the dialog box that come up, select the Paste button and
%PRODUCT Entities. That should do it. Good luck
Sem Solomon
"gshaner" wrote in message
news:f133b38.-1@WebX.maYIadrTaRb...
Active Contributor
gshaner
Message 5 of 8 (89 Views)
Re: Excel Spread Sheet into AutoCad
12-26-2002 10:47 PM in reply to: gshaner
Hey Terry I looked at the XL2CAD product, and it looks very helpful. Have you used it, and or still using it??? Do you encounter any problems with it??
*Dotson, Terry W.
Message 6 of 8 (89 Views)
12-27-2002 02:30 AM in reply to: gshaner
> problems with it??
Since I'm the developer my opinion would be biased. :-)
Why not try the demo {http://www.dotsoft.com/demo.htm}?
Terry
*White, Glenn
Message 7 of 8 (89 Views)
12-27-2002 02:39 AM in reply to: gshaner
a friend of mine got it just a while back and is very pleased with it - you
can find some really good stuff at dotsoft
"Terry W. Dotson" wrote in message
news:3E0C9C2E.D980215C@dotsoft.com...
> > problems with it??
> Terry
*Shea, Tim
Message 8 of 8 (89 Views)
01-02-2003 10:32 AM in reply to: gshaner
I'm using XL2CAD and am very pleased. I have not
had any problems.
Tim
I
Announcements
Need installation help?
