ASE, SQL, OLE, ADE
ASE, SQL, OLE, ADE
*Adam, Claire
Message 1 of 4 (104 Views)
Access Table Names
104 Views, 3 Replies
10-27-1999 01:36 AM
Dear all,
I want to be able to list all tables within an access data base from visual
basic. I use the commands below:
'list all tables within the database file
Dim tdfNew As TableDef
Dim tdfLoop As TableDef
Dim dbsMyDataBase As Database
Set dbsMyDataBase = OpenDatabase(lblDataBaseName.Caption)
With dbsMyDataBase
' Enumerate TableDefs collection.
For Each tdfLoop In .TableDefs
Debug.Print " " & tdfLoop.Name
Next tdfLoop
.Close
End With
This works well as i get all the tables listed in the data base but I also
get the following listed:
MSysACEs
MSysModules
MSysModules2
MSysObjects
MSysQueries
MSysRelationships
Is there any way of filtering these out or any other unknown tabledef
objects.
thanks
Claire
*Poat, Alan
Message 2 of 4 (104 Views)
Re: Access Table Names
10-27-1999 07:58 AM in reply to: *Adam, Claire
Try this After your for Each statement:
If Left (tdfloop.Name, 4) <> "MSys" Then
Next tdfLoop
This orks in VB.
Claire Adam wrote:
> Dear all,
> With dbsMyDataBase
> Next tdfLoop
> .Close
> End With
> MSysACEs
> MSysModules
> MSysModules2
> MSysObjects
> MSysQueries
> MSysRelationships
> objects.
> thanks
> Claire
Alan Poat
DisplayWorks
470 Valley Drive
Brisbane, CA 94005
Phone: 415-467-0198
Fax: 415-467-8371
Email: apoat@displayworks.com
http://www.displayworks.com
*Holder, Mark
Message 3 of 4 (104 Views)
Re:
10-27-1999 10:28 AM in reply to: *Adam, Claire
TableDefs also have an Attributes property, which is a bitmapped value that
indicates not only system tables, but attached tables as well. See the online
docs for TableDef Attributes property.
Mark Holder
> End If
> Next tdfLoop
> This orks in VB.
> Claire Adam wrote:
> > Dear all,
> > With dbsMyDataBase
> > Next tdfLoop
> > .Close
> > End With
> > MSysACEs
> > MSysModules
> > MSysModules2
> > MSysObjects
> > MSysQueries
> > MSysRelationships
> > objects.
> > thanks
> > Claire
> Alan Poat
> DisplayWorks
> 470 Valley Drive
> Brisbane, CA 94005
> Phone: 415-467-0198
> Fax: 415-467-8371
*Watts, Steve
Message 4 of 4 (104 Views)
Re:
10-27-1999 04:31 PM in reply to: *Adam, Claire
Here is a portion of the code I use to fill a list box with valid table
names:
Dim dbss As Database, tdf As TableDef
Static dbs(127) As String, Entries As Integer
' Return reference to current database.
Set dbss = CurrentDb
Entries = 0
For Each tdf In dbss.TableDefs
' Compare property setting and constant in question.
If (tdf.Attributes And dbSystemObject) Or _
(tdf.Attributes And dbHiddenObject) Then
Else: dbs(Entries) = tdf.Name
Entries = Entries + 1
Next tdf
Set dbss = Nothing
Steve
Alan Poat wrote in message
news:3817132A.E2A11893@displayworks.com...
> End If
> Next tdfLoop
> This orks in VB.
> Claire Adam wrote:
> > Dear all,
visual
> > With dbsMyDataBase
> > Next tdfLoop
> > .Close
> > End With
also
> > MSysACEs
> > MSysModules
> > MSysModules2
> > MSysObjects
> > MSysQueries
> > MSysRelationships
> > objects.
> > thanks
> > Claire
> Alan Poat
> DisplayWorks
> 470 Valley Drive
> Brisbane, CA 94005
> Phone: 415-467-0198
> Fax: 415-467-8371
Announcements
Need installation help?
