AREA Website Support Forum
This section is for questions on the use of the AREA website or reporting website issues. This area is not for Autodesk software support issues.
Best work flow for Architect
1 REPLY 1
joeinck
339 Views, 1 Reply
Greetings,
I am an Architect and have used Autocad and Revit for a long time.
I have a pretty typical work process, pencil sketching -----> Revit -------> CD's; pretty typical.
Now I want to invest the time and energy into learning the rendering or animating or modeling software so that I can create "WOW" presentations that will be presented both digitally and on paper (lets leave plotter quality out of the mix).
I have a model already built in Revit....now I need to make it sing; what should I use next?
thanks
James Oeinck
1 REPLY 1
nicolasleduc
in reply to: joeinck
You should look at 3ds Max Design for this (http://www.autodesk.com/products/3ds-max-design/overview) . If you have more questions about this you should visit the 3ds Max forums: http://forums.autodesk.com/t5/3ds-max/ct-p/area-c1
