Transfering Math (Trig functions) to Fusion 360.
Will you show me how to convert (from paper) trig functions (epicycloid curve and hypocycloid curve) into Fusion 360?  Thank you.
ekinsb
Fusion doesn't currently support the ability to create a curve given an equation.  However, using the API you can draw a curve that approximates an equation.  The Python code below is a simple example.  Basically, you code your equation in Python and use it to calculate points along the curve defined by your equation.  You can then create a spline in Fusion that fits through the points.  In your case you mentioned epicycloid hypocycloid curves.  You would do the same thing but you would also want to break the calculation up so each lobe is calculated seperately and created as a single spline.  If you tried to create them all as a single spline it would smooth out the cusps.
import adsk.core, adsk.fusion, traceback
import math
def run(context):
    ui = None
    try:
        app = adsk.core.Application.get()
        ui  = app.userInterface
        des = app.activeProduct
        root = des.rootComponent
        sketch = root.sketches.add(root.xYConstructionPlane)
        pnts = adsk.core.ObjectCollection.create()
        lowX = -3
        highX = 3
        num = 20
        for val in range(0,num):
            x = ((highX - lowX) * (val/(num-1))) + lowX
            y = x * x + 3
            pnts.add(adsk.core.Point3D.create(x,y,0))
        sketch.sketchCurves.sketchFittedSplines.add(pnts)
    except:
        if ui:
            ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
Brian Ekins
Mod the Machine blog
Thank you, Brian for taking time to answer my inquiry.  You did a fantastic job not only explaining it well, but also in a courteous and class way.
Best to you,
Tom
