Mathematically created line
codefoster
codefoster
If a person wanted to create a line using a mathematical algorithm via the JavaScript API, how would that go? I'm thinking it would be hard, because it would not necessarily be a simple array of points run through the function, but would also have to be converted to a F360's line with handles and curves. Is there an elegant way to do this? I'm thinking of recreating the grooves in a project like [this].
ekinsb
Mathemattically, a line is a straight segment between two points.  I think what you want is a curve.  You can create a spline through a series of points.  This is demonstrated in the sample in Fusion's help.  Here's a direct link:
http://help.autodesk.com/cloudhelp/ENU/Fusion-360-API/files/CreateFittedSpline_Sample.htm
Brian Ekins
Mod the Machine blog
codefoster
Excellent. Thanks for the clarification and the link.
jf
codefoster
wh6Q9NU
Link seems to be broken. Any change I can access this example somewhere? Many thanks!
example link: http://help.autodesk.com/cloudhelp/ENU/Fusion-360-API/files/CreateFittedSpline_Sample.htm
ekinsb
Try this link.  It's should take you to the same link referenced above.
http://help.autodesk.com/view/NINVFUS/ENU/?guid=GUID-c3d4a306-fade-11e4-8e56-3417ebd3d5be
Brian Ekins
