I am working with FaceRobot in order to create an animation of a person speaking given the text and the audio files. I am now able to export the animation to a video file (avi), but I need also to have the transcription of the phonemes and of their starting/ending time-points. Do you know if it is possible to export this information in a text file or if it is possible to retrieve it somehow? If not, could you please indicate me a software or a publication related to lip syncronisation?
Thanks a million,
Giovanni
Solved by lucericr. Go to Solution.
with scripting. The lipsync ends up on the animatino mixer, and you can get the data out with
GetPhonemeBlendFromSpeechClip
or you could call the command directly that does the phoneme analysis.
it's called
SIExtractPhonemes
