Softimage Forum (Read Only)
Welcome to Autodesk’s Softimage Forums. Share your knowledge, ask questions, and explore popular Softimage topics.
Exporting to UDK
1 REPLY 1
574 Views, 1 Reply
Exporting to UDK
Hi everyone, I'm trying to export my character model to UDK (Unreal Developement Kit) using fbx format. I can do so successfully, however my character has two skeleton poses stored in the animation mixer. I want to export the second pose into UDK instead of the reference pose, but even if I export the posed envelope/skeleton (and delete the reference pose in the anim mixer) it still imports into UDK in the reference pose. I feel like Softimage is tricking me somehow and making me think I'm exporting the posed model when the reference pose still exists somewhere. Any suggestions? Thank you.
1 REPLY 1
I would suggest you to try using the .ASE format, you could found it if you install the AcrotX plugin for Softimage ( it is still for version 6.5 but I'm currently using it on XSI2013 and it works perfectly )
In there you can export your skeletal mesh or statich mesh as you want.
I usually use FBX for static mesh and ASE for skeletal meshes, works quite good 😉
