3ds Max Animation and Rigging
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max animation topics.
Possible to have a fixed distance to target with camera?
3 REPLIES 3
niekbraam
783 Views, 3 Replies
I'm trying to rotate a target cam around an object. It is part of a bigger animation. so the use of a spline would be no option.
Is there a way to retain a fixed distance between the camera and the cameras target?
____________________________________________________________________
3ds Max Design 2011
Win7 HP Xeon 16 core 3.30 GHz
32 RAM with Nvidia Quadro K5000
3 REPLIES 3
Steve_Curley
in reply to: niekbraam
Create a Dummy. Align it (pivot-to-pivot probably) to the Object. Select and Link the Camera to the Dummy. Animate the rotation of the Dummy and the Camera will rotate along with it, at a fixed distance.
If the Object is moving (or itself rotating) and you want the Camera to mimic that movement, Select and Link the Dummy to the Object.
Max 2016 (SP1/EXT1)
Win7Pro x64 (SP1). i5-3570K @ 4.4GHz, 8Gb Ram, DX11.
nVidia GTX760 (2GB) (Driver 430.86).
niekbraam
in reply to: Steve_Curley
Thanks Steve!
It's more of a 'workaround' but I guess the only option.
3ds Max Design 2011
Steve_Curley
No, it is not a workaround. That is the accepted method for rotating an object around a point which is not that object's pivot point. It allows for that object to spin on its own axes separately from, and in addition to, its rotation around the point, which is virtually impossible any other way.
Max 2016 (SP1/EXT1)
