Solved by Cagetron. Go to Solution.
Right click on the Ankle control and create an Aux Pivot. Hit insert to go into pivot mode and move the Aux Pivot to the ball of the foot. Pin the rotation of the Toe Base control. Now you can use the Aux Pivot as a ball roll control. You can add more pivots as needed for the heel, side of the foot etc. This probably isn't exactly what you're used to on your other rig, but it should function pretty close.
