Hello everybody,
I'm thinking that this might be the solution, but at the moment I can't figure out how to do it.
Please take a look at my image (open in a new tab):
Any thoughts?
Solved by hazmondo. Go to Solution.
Hello, I think what you want to use is a Float List controller on the particular rotation axis' of your wings, I've attached an example for you to look through.
-Harry
Exactly! I'm still learning rigging and It can easily prove an confusing/frustrating process.
Although I've managed to do my job with a workaround, I'm definitely going to change my rig.
Thank you very much.
PS: Because I wired the Attributes through Reaction Manager, I had to go to "Dope Sheet" to be able to apply "Float List" to the "Spread etc" Attributes and not through Motion Panel.
