Heres the deal:
Camera animation starts on the inside and goes around to the outside. I need to edit the key frames so as to make it slow down between f150 to f200 so that i get a slow zoom out effect, know what i mean? How can i edit the keyframes to achieve this. It does not seem to work by adding the keyframes manually in between. Thx for any help.
Yes but moving the keyframes furthur apart will slow the whole animation down. I need it to be slower only when the cam reaches the end of the circle/helix, that is when it moves back on the straight line. So it has 2 speed on the path, lets say starts at F0 and reaches end of circle at F150 with normal speed and as from F150 to F200, it moves real slow on the straight line. Thats why adding a keyframe in between start frame and end frame would have been easy if that is possible.
