Hello
I know about motion paths, but these don't seem to give me what i need, as I do not want the timeline to govern where my locators are postioned along the cv curve - i want them to remain at their positions (.4, .625, etc) regardless of where the timeline is or where the control verts get moved to.
In max, you can path constrain locators to a curve - deleting the animation from those now constrained locators leaves them constrained to the curve - now you can set what percentage along the curve they should stay - 0, .25, .5, .75, 1 - when you translate the points of the curve, the locators stay on the curve
this is what I'm trying to achieve in maya
any help would be great, thanks!
colleague solved it - create the curve, create a locator - attach locator to curve (attach to motion path) - open up hypergraph:connections, delete only the anim curve connection
Hey, thanks for figuring it out and then posting the solution here!
A quick note for total hypergraph noobs (like me):
In the hypergraph, click on the object that is connected to the motion path and select from the top menu "Graph --> Input and Output Connections" to expose the animation curve input.
Now under your "Inputs" on the object that is connected to the motion curve you can modify and "U" value and it will be independant of the timeline.
