Area :: Header
Discover the Difference with
3ds Max 2015
Upgrade now and save
Discussion Groups
Animation and Rigging
Active Member
cartlamoon
Constrain foot to pedal/put pedal in place?
91 Views, 3 Replies
03-08-2013 03:57 AM
Hi everyody,
I have a character on a monocycle and what we did was constraining stuff to stuff which I didn't quite understand. Understanding it is not so important for now, it should work in the first place - but doesn't.
We
- pushed the pedals out of the monocycle structure in outliner
- constraint:smileytongue:oint the foot to the pedal
- constraint:smileytongue:oint the pedal to the wheel axis
- constraint:smileysurprised:rient the ankle joint to the pedal
- constraint:smileytongue:oint the ikHandle to the pedal.
Please correct the list above if you feel there's a mistake.
Now that we've pushed the pedal out of its place in the monocycle structure, I don't know what to do with it. When i place it where it was before it won't work properly. Perhaps I have to do further steps but this is all I got in class yesterday.
Can anybody tell me what to do next or how I can make this work?
Please use plain text.
Active Member
cartlamoon
Re: Constrain foot to pedal/put pedal in place?
03-08-2013 04:20 AM in reply to: cartlamoon
Let's say the constraints were set right (which I doubt...) - when I put the pedal back to the monocycle in outliner and turn the wheel, this is what happens:
Valued Contributor
pened
03-09-2013 02:13 AM in reply to: cartlamoon
my name is Peter. I think you have bad connection between pedal and crank. It´s like on real bike. Your pedal never rotates 360 degres about his Z axel. Look at my attached scene. There is parent constraint between pedal and crank with forbiden rotation for pedal in constrain condition.
Dammit I can´t make attachment, I don´t know why.
You can download it from that link
www.pened.cz/modely/pedalScene_test.7z
btw: I just finished test with my character on that bike and it works corectly. I made point constraint between pedals and legs´ controls and it works very well.
Moderator
Steve_Curley
03-09-2013 04:18 AM in reply to: pened
Please read this post for help with attachments.
Hint. Files must be Zipped - .rar, .7z and all other alternative compressed file types will not attach.
Max 4.2 through 2015 (SP2+EXT1), Composite 2014.
Win7Pro x64 (SP1). i5-3570K @ 4.4GHz, 8Gb Ram, DX11.
nVidia GTX760 (2GB) (Driver 335.23).
