3ds Max Animation and Rigging
Welcome to Autodesk’s 3ds Max Forums. Share your knowledge, ask questions, and explore popular 3ds Max animation topics.
3ds Max Rigging one child to two parents
2 REPLIES 2
922 Views, 2 Replies
I've been building a robot for a while now and I'm stuck with one of the shoulder mechanisms. I'm trying to link one sphere to one shoulder blade, and the second one to the outer shoulder blade. So I could move the outer shoulderblade, and the 4 balls touching that side would move along with it, but would just rotate and not be transformed or the mesh changed any way. When I move the inner bigger shoulder blade, the whole thing would move as a whole. I attached two pictures to hopefully help with this problem. THANKS!
2 REPLIES 2
You may have figured this out but the way I would do it is for each piston, use a look at constraint and create a point helper for the the target to look at. Link the piston to the shoulder and the piston's look at target to the main body. This way, when you rotate the shoulder, the piston will automatically rotate to look at the target.
It works well as far as I've seen... and there's also this video for a sliding piston: http://www.youtube.com/watch?v=LKG5aX0KYl8
paulneale
I believe that I cover it in this video.
http://au.autodesk.com/au-online/classes-on-demand/class-catalog/classes/year-2013/3ds-max/dg1989
Paul Neale
http://paulneale.com
Paul Neale
