I would like to see some more flexibility and even a total redesign of the floating windows. Control panel and diagnostics window in particular.
I use a dual monitor to dock some of those windows to free up the graphics view and number one on my list is
to be able to size the window horizontal as well as vertical, very annoying to have to constantly scroll to get where you need to go.
Second: Personally I never use the shelf area in the control panel but there is no way to get rid of it, I can customize my shelf window how I want it
to look, and size it horizontal or vertical, why can I not do the same with the other windows in Alias and why should they behave any different
from the customization that works quite well with the shelf window? Especially true in the visualization workflow when you are trying to assign shaders
to the model and to look at your shader material icons you have to scroll through the very narrow vertical only to get the material you want (drives me crazy)
Thanks Much, for the great work on the tutorials, big help. Buddy.
