In a tool like Surface Filet, if a surface and a curve are under you cursor when you click, the Pick Chooser gives you the option to select the curve - even though selecting a curve is not a valid input for the Surface Filet tool.
Alias should know what is valid in the context of the tool and ignore those as selection options.
