I just got Alias as part of the new suites so I wanted to do a simple test. I exported an iges from inventor and imported it into alias - no problem. Now I want to export as iges. I cant find the export settings as shown in the help and the dialog boxes for save as and export active both have the file types greyed out so I cant choose iges format. What's gone wrong ?
You need to select the surfaces/objects you want to export, and then go to File > Export > Active As...
A little strange workflow I'll give you.
Can anyone help me with this, I have that option to export as IGS grey even with an object selected.
Is this because its a 30 day trial????
Thanks!
Hello
as posted already next to the save as funktion is a little grey box, this is called option box, click on it and the export options are opening, there you can select all kind of different formats.
Best regards,
Rüdiger Ambs
