I am new to Alias and wondering how I can use data a created in Inventor. Is there any special interchangeable format? I saved my model in Inventor as a *.step and *.igs-file. I can load the data into Alias but then I am not able to pick or manipulate any of the points of the model. Can anyone help me?
Max
Solved by TheHangman. Go to Solution.
Hi mas10349
No worries its simple... Select your object then > Pallet > Surface Edit > Stitch/ Unstitch
Please see the image bellow.
Hope it helps happy modelling.
if this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudos are appreciated. Thanks!!!!
