hmm, when You check your model in Alias with higher tolerance settings and it shows gaps, then the gaps are there.
I build models usually on 0.002 mm position for ProE. But Rhino gives me trouble even when modeling on 0.0001mm.
Succsessfull stitching is not a sign for having a "watertight" model. Some Software packages (ProE) handle exported stitched data like volumes even if You loosen tolerance. But others do not.
Also stitching actually can change your geometry when stitching gappy geometry with loosened tolerances. I had this a few times.
And sometimes the model will be not closed even if you built it on zero tolerance in Alias. This must be something with calculating data between file formats.
I do not know of any easy way to "heal" the geometry. You have to model it within the requested tolerance.
If anyone knows more about it, news are highly appreciated 🙂
Greetings
Tobias
