see the attached image.
best, jamie.
@tudorima, can you share your file?
I found a way to do it, but is a bit complex.... I am waiting for gilchrj to show is answer..... Maybe he can do it in a easier way.
So, we are waiting for you gilchrj, in case you can do it the way you described.
Looking forward for your solution
Regards
I have tried something. Pls check it out.
Hope it will help u.
Wasnt it a lot better to post the wire file?
Anyway.... Nice try, but your surfaces look not good. Look at those kinks.... You can see where all boundaries are, just by looking. In Solidworks, this can be done with 2 or 3 mouse clicks....But surfaces arent as good as they claim it to be...In alias, this is quite hard to do well.
Good try mate.
What i have shown is just an explanatory.
The parent surf is also responsible for those kinks ( I beleive so). But still i m sure i can make it neat.
The Parent surf. itself has kinks on it. If u watch his image u could see them.
I dont want to spend more time were as my motive was to post an idea to solve the issue.
II never tried solid works.
But, nothing is HARD in alias until we make things right.
Hi dude,
you didnt do it right, in case you didnt notice....LOL
And the only way to learn is really to do it right, and not stop halfway.
If you can do it right, why didnt you do it then? Can you actually do it a lot neater?
I understand it was only to show idea...fine..... But to make it right, and not half right, i would say is the direction to go .
The way you showed by the way, is not very good, and you will not make it right i think with that patch layout.
You see.... You have a square with right edges..... And that does not blend with the rest of the surface... does not flow correctly at all.
If you try a bit harder, I ll show you my way, which is a little bit more complex, i use one more surface or two, but it flows a lot better with that surface shape.
Regards 🙂 ..... Give it another try mate 🙂
Sorry, if I'm late to the party...I just wanted to give this one a shot.
Please refer to the attached screen shots:
I had to re-construct every surface because the original ones were not usable; the curves were not well shaped and the surfaces were much too complex. The new surfaces are different of course, but I did try to keep to the original design as much as I had time for. All surface boundaries are G2 Curvature continuous and all Isoparams are showing.
As someone pointed out earlier, all surfaces are four sided, however you can Trim them to create whatever shape you'd like. The trick here is in the small Trimmed patch on the right side of the attached image. A similar thing happens on the lower side.
Good luck!
Are those spans, in the top radial piece?
Since you didnt provide the wire file (god knows why), we cant really see what u did too well.
I have a pretty good idea, but not sure about everything. How did u get that middle curve?
Anyway, thanks for joining the party mate.... Very nice solution. Looks clean:)
Regards
Yes, degree 5 - 6 spans. That surface started out with 2 spans like the surface below it, but the extra complexity was necessary for matching the trimmed patch on top. It might be possible to make it a single span surface if I increase the degree and split the surfaces down the middle, but that would take more time. I already spent a whole hour on this, so I don't really feel like investing any more time on it...but I'm reasonably sure it can be done. The same goes for the under side.
I built it....? I'm not sure what your question is.
Attached are a few more screen shots in case anyone is still unclear about what I did.
Thanks for your time . Yeah, basically is the same solution i had made.
Cant really think of a better way of doing this.
Regards mate
You see, spans are not evil. Everyone's all like "no spans no spans!" but that piece right there, is a blended transition that you will not very likely want to direct model. So it's ok! I guess the best advice I can give regarding spans is: if you plan to direct manipulate cv's afterwards, don't use spans, because they make the cv/hull unreadable and make direct modeling difficult afterwards.
That could and should have been made with 1 span surfaces.
Of course it s harder, but perfectly possible.... And is the right way to do it using alias.
Anyway, most of us model for rendering purposes, etc.... So some spans will not hurt , that s fine. But in alias, spans are bad, regarding best sufacing practices. I always get pissed off if i cannot make things with 1 span all over....LOL, but if it is giving me a big headache, i wont spend precious time just for the sake of it if it looks good enough.
Anyway, every person has their own standards .
